Engine Engine Configuration I
Cylinders 3
Engine VTEC®.
Aspiration/Induction Normal
Displacement 995.00 cc | 60.7 cu in. | 1 L.
Valves 12 valves.
4 valves per cylinder.
Valvetrain SOHC
Horsepower 67.00 BHP (49.3 KW) @ 5700.00 RPM
Torque 66.00 Ft-Lbs (89.5 NM) @ 4800.00 RPM
HP to Weight Ratio 27.6 LB / HP (Vehicles with similar ratio)
HP / Liter 67.0 BHP / Liter
Bore 72.00 mm | 2.8 in.
Stroke 81.50 mm | 3.2 in.
Compression Ratio 10.8:1
Fuel Type Gasoline - Petrol
Fuel Feed Fuel Injected
Multi-Point Fuel Injection - Lean-Burn
Block Aluminum
Head Aluminum
Ignition System Direct Ignition System with Immobilizer
Hybrid System Electric Motor
Type Permanent magnet electric motor
ELECTRIC MOTOR / GENERATOR
Power Output 14.00 HP @ 3000.00 RPM
Battery
Type Sealed Nickel-Metal Hydride (Ni-MH)
Voltage 144.00V
