Gönderen Konu: K Serisi Honda Motorları  (Okunma sayısı 28746 defa)
« : Ekim 24, 2006, 06:24:24 ÖS »
K20A• Found in:
o 2002-2005 Honda Civic Type-R (EP3)
o 2001-2006 Honda Integra Type-R(DC5)
• Displacement: 1998 cc
• Compression: 11.5:1
• Power: 220 hp (162 kW) @ 8000 rpm
• Torque: 152 ft•lbf (206 N•m) @ 7000 rpm
• Redline: 8500 rpm
o 2003-2006 Honda Accord Euro-R
• Redline: 8500 rpm
K20A2• Found in:
o 2002-2004 Acura RSX Type-S and 2002-2005 Honda Civic Type R (EP, European)
• Compression: 11.0:1
• Power: 200 hp (149 kW) @ 7400 rpm
• Torque: 142 ft•lbf (193 N•m) @ 6000 rpm
• Redline: 7900 rpm
K20A3• Found in:
o 2002-2005 Honda Civic Si
• Compression: 9.8:1
• Power: 160 hp (119 kW) @ 6500 rpm
• Torque: 132 ft•lbf (179 N•m) @ 5000 rpm
• Redline: 6800 rpm
o 2002-2006 Acura RSX
• Torque: 141 ft•lbf (191 N•m) @ 4000 rpm
• Redline: 6800 rpm
K20Z1
• Found in:
o 2005-2006 Acura RSX-S
• Power: 201 hp (150 kW) @ 7800 rpm (sae NET Rev 8/04)
• Torque: 140 ft•lbf (194 N•m) @ 7000 rpm (sae NET Rev 8/04)
• Redline: 8400 rpm
K20Z2• Found in:
o 2006- Acura CSX (Canada)
• Compression: 9.6:1
• Power: 155 hp (114 kW) @ 6000 rpm (sae NET Rev 8/04)
• Torque: 139 ft•lbf (188 N•m) @ 4500 rpm / 188 N•m @ 4200 rpm (Singapore)
• Redline: 6800 rpm
o 2006- Honda Civic (JDM)
• Redline: 6800 rpm
K20Z3• Found in: 2006 Honda Civic Si
• Displacement : 1998 cc
• Compression : 11.0:1
• Power: 197 bhp (147 kW) @ 7800 rpm (sae NET Rev 8/04)
• Torque: 139 lb•ft (189 N•m) @ 6200 rpm (sae NET Rev 8/04)
• Redline: 8000 rpm
K23
K23A1• Turbocharged
• Found in:
o 2007 Acura RDX
• Displacement: 2300 cc (acura.com)
• Compression: 8.8:1 (acura.com)
• Power: 238 hp @ 6000 rpm (SAE net)
• Torque: 260 ft•lbf @ 4500 rpm (SAE net)
• Redline: 6800 (acura.com)
• Bore: 86 mm
• Stroke: 99 mm
K24
K24A1• Found in:
o 2002-2006 Honda CR-V
• Displacement: 2354 cc
• Power: 160 hp (119 kW) @ 6000 rpm
• Torque: 162 ft•lbf (220 N•m) @ 3600 rpm
• Redline: 6500 rpm
K24A2• Found in:
o 2004-2006 Acura TSX
• Compression: 10.5:1
• Power: 205 hp (149 kW) @ 6800 rpm
• Torque: 166 ft•lbf (225 N•m) @ 4500 rpm
• Redline: 7100 rpm
K24A3• Found in:
o 2003-2006 Honda Accord (Europe, Japan, and Australia)
• Power: 189 hp (140 kW) @ 6800 rpm
• Torque: 164.5 ft•lbf (223 N•m) @ 4500 rpm
• Redline: 7000 rpm
K24A4• Found in:
o 2003-2005 Honda Accord, 2003-2006 Honda Element
• Compression: 9.7:1
• Power: 160 hp (119 kW) @ 5500 rpm
• Torque: 161 ft•lbf (218 N•m) @ 4500 rpm
• Redline: 6500 rpm
K24A8• Found in:
o 2006/2007 Honda Accord
• Bore and Stroke: 87 mm * 99 mm (3.43x3.90 inches)
• Power: 166 hp (124 kW) @ 6000 RPM
• Torque: 160 ft•lbf @ 4000 rpm
• Redline: 6500 rpm
Ynt: K Serisi Honda Motorları
« Yanıtla #1 : Ekim 24, 2006, 06:27:32 ÖS »
CHASSIS, POWER, REDLINE, C/R, BORE X STROKE, SIZE, TRANSMISSION
K20A (PRC/RBC) 2002+ Integra Type-R/Accord Euro-R (Japan)
220hp @ 8000rpm / 21kgm @ 7000rpm
8400rpm
11.5:1
86mm x 86mm
1998cc
6 Speed Manual (helical LSD)
K20A2 (PRB) 2002-2004 RSX Type-S (DC5)
200hp @ 7400rpm / 142lb-ft @ 6000rpm
7900rpm
11.0:1
86mm x 86mm
1998cc
6 Speed Manual
K20A3 (PND/PNF) 2002+ Civic Si (EP) / base RSX (DC5)
160hp @ 6500rpm / 141lb-ft @ 4000rpm
6800rpm
9.8:1
86mm x 86mm
1998cc
5 Speed Manual
K20C 2002+ Civic Type-R (EP Euro/Japan)
215hp @ 8000rpm / 20kgm @ 7000rpm
8400rpm
11.0:1
86mm x 86mm
1998cc
K20Z3 2006 Civic Si coupe (FG)
197hp @ 7800rpm / 139lb-ft @ 6200rpm
8500rpm
11.0:1
86mm x 86mm
1998cc
K24A1 (PPA) 2002-2004 CR-V (LRD)
160hp @ 6000rpm / 162lb-ft @ 3600rpm
6500rpm
9.6:1
87mm x 99mm
2354cc
5 Speed Manual (FWD/AWD)
K24A2 (RBB) 2002+ TSX (CL)
200hp @ 6800rpm / 166lb-ft @ 4500rpm
7100rpm
10.5:1
87mm x 99mm
2354cc
6 Speed Manual
K24A3 (RAA) 2002-2004 Accord (CE)
160hp @ 5500rpm / 161lb-ft @ 4500rpm
6500rpm
9.7:1
87mm x 99mm
2354cc
5 Speed Manual
K24A4 (PZD) 2002+ Element
6500rpm
9.7:1
87mm x 99mm
2354cc
Onu-R
  • İleti: 3113
« Yanıtla #2 : Ekim 24, 2006, 06:38:05 ÖS »
K20A• Found in:
• Redline: 8500 rpm
• Redline: 8500 rpm
K20A2• Found in:
• Redline: 7900 rpm
   K20A JDM type-R da olan motorun kodu değil mi? A2 olan da ülkemizde bulunan type-R'ların (yani EDM)  :roll:
« Yanıtla #3 : Ekim 24, 2006, 06:39:51 ÖS »
evet Onur.
Onu-R
  • İleti: 3113
« Yanıtla #4 : Ekim 24, 2006, 06:48:43 ÖS »
   Tamam abi saolasın, paylaşım için de saol buarada...
 K23A1  ilgimi çekti ya :)  Değişik..
« Yanıtla #5 : Ekim 24, 2006, 06:53:43 ÖS »
ağzın sulanmasın  ;D malesef USDM  :'(
Onu-R
  • İleti: 3113
« Yanıtla #6 : Ekim 24, 2006, 07:22:15 ÖS »
   Eheheh yok abi sulanmadı ya, 2.3 litre turbo motor 238 beygir üretmiş, redline 6800 devir falan, bana göre değil, K20A2 ye taksak turboyu olmuyor mu ;D :zipla
aSil
  • İleti: 989
« Yanıtla #7 : Ekim 24, 2006, 10:08:27 ÖS »
Değerli bilgiler. Paylaşım için teşekkürler...
« Yanıtla #8 : Ekim 24, 2006, 10:11:13 ÖS »
bu hacimle daha iyi işler yapılır  ;)
Tolga-R
  • İleti: 362
« Yanıtla #9 : Ekim 24, 2006, 10:52:11 ÖS »
peki bişey sorucam
k20a2 nin sıkıştımasını 11.5.1 yaparsak + yazılım ile 20hp alabilirmiyiz. JDM olurmu yani :)
« Yanıtla #10 : Ekim 24, 2006, 11:32:41 ÖS »
k20a2 hondata beyinle JDM oluyor
Tolga-R
  • İleti: 362
« Yanıtla #11 : Ekim 24, 2006, 11:39:35 ÖS »
peki hondata nın yanında sıkıştırma 11.5 yapılırsa ne olur ?
« Yanıtla #12 : Ekim 24, 2006, 11:54:30 ÖS »
dikkat edersen JDM ve EDM type r dada bore-stroke oranları aynı, sıkıstırmadaki fark piggy back ayarlarla yapılabiliyor zaten..
« Yanıtla #13 : Ekim 24, 2006, 11:58:56 ÖS »
şunuda ilave etmek isterim;
üst kapak conta (headgasket) değşimi, piston kafalarının ve yuvalarının polishi ve yuksek basınca musade eden pistonlarlada sıkıştırmaya etki edebilirsin..
R-13239
« Yanıtla #14 : Ekim 25, 2006, 02:25:17 ÖÖ »
Teşekkürler abi paylaşım için , hakkaten süper bilgiler..
« Yanıtla #15 : Ekim 25, 2006, 02:48:17 ÖS »
rica ederim Kaan  ;)
arl_38honda
« Yanıtla #16 : Aralık 06, 2006, 05:19:14 ÖS »
Paylaşım için Teşekkürler..:)
SKUNKSTER
« Yanıtla #17 : Aralık 13, 2006, 10:59:13 ÖS »
peki bişey sorucam
çok daha fazlasini da alirsin :)
type-RRR
  • İleti: 660
« Yanıtla #18 : Aralık 14, 2006, 09:21:49 ÖÖ »
paylaşım için tşk
serkan
« Yanıtla #19 : Aralık 14, 2006, 10:51:00 ÖÖ »
Hepsi varda bi K20A6 yok be tühh ](*,)
caucass
« Yanıtla #20 : Ekim 07, 2007, 04:32:14 ÖS »
saaool allah razı olsun
SuperSonic
  • İleti: 1432
« Yanıtla #21 : Ekim 16, 2007, 06:37:18 ÖS »
Headgasket değişimi çabuk ve kolay oluyor mu? Yoksa motoru açmaya değmez mi?  Hondata beyin takıp motoru açmadan yola devam mı?
systemcar
  • İleti: 131
« Yanıtla #22 : Mart 31, 2008, 10:18:07 ÖÖ »
çok güzel bir paylaşım
hakangunister
  • İleti: 6836
    • www.osgun.com.tr
« Yanıtla #23 : Haziran 11, 2009, 11:01:59 ÖS »
paylaşım için çok teşekkürler
34BB9000
  • İleti: 133
« Yanıtla #24 : Temmuz 12, 2009, 03:39:07 ÖS »
K23A1• Turbocharged :))
