Aracıma alarm aldım kendim bağlamak istedim.Aracın elektrik bağlantı şeması aşağıdaki gibiymiş;Araca alarmı bağladıktan sonra kabloların doğru olup olmadığını sizlerle tekrardan paylaşırım.
PART COLOR LOCATION
12 VOLT CONSTANT WHITE (+) IGNITION SWITCH HARNESS
STARTER BLACK/WHITE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 YELLOW (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 WHITE/BLACK (+) IGNITION SWITCH HARNESS
KEYSENSE N/A
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) RED/BLACK (+) IN DRIVERS KICK PANEL
POWER LOCK GREEN/WHITE (Negative (-)) @ BLUE PLUG IN DRIVERS KICK PANEL
POWER UNLOCK GREEN/ORANGE (Negative (-)) @ BLUE PLUG IN DRIVERS KICK PANEL
DOOR TRIGGER LIGHT GREEN/RED (-) LOW IN DRIVERS KICK PANEL
DOMELIGHT SUPERVISION LIGHT GREEN/BLACK (-), IN DRIVERS A PILLAR
Requires Part #R30-H Relay
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN BLUE to GRAY @ STEERING COLUMN HARNESS
TACH BLUE, See NOTE *1 @ TACH TEST CONNECTOR
WAIT TO START LIGHT N/A
BRAKE GREEN/WHITE (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM N/A
ANTI-THEFT N/A
