Gönderen Konu: Air-Fuel Ratio  (Okunma sayısı 2370 defa)
Air-Fuel Ratio
« : Aralık 18, 2005, 08:38:52 ÖS »
Air-Fuel Ratio and the SRF Air-Fuel Curve
Background
 One of the key elements determining performance, driveability and reliability of gasoline fueled internal combustion engines is precise control of the air-fuel ratio.  Efficient combustion occurs within a fairly narrow band of mixtures...with increased fuel consumption, increased exhaust emissions and potential engine damage possible outside this band.  This was one of the key factors driving the adoption of computer controlled engine management systems in passenger cars.
In the Spec Racer Ford, we have no direct control over the air-fuel ratio--it’s set by the “fuel map” programmed into the EEC.  Knowing what’s going on, however, can help you maximize power and minimize the potential for engine damage.
Air-Fuel Ratio Basics
 Air-Fuel Ratio and Power
Air-fuel ratio is measured in terms of mass....with air being the first (and larger number).  For example, an air-fuel ratio of 12:1 means for every one given mass of fuel, you have 12 times the mass in air.  The graph below illustrates a few key points.  First, the concept of stoichiometric mixture...that is the point where, chemically, there are exactly enough atoms of oxygen to burn 100% of the fuel.  This point is at an air-fuel ratio of 14.7:1.  If you have more air with same amount of fuel you have a lean mixture, less air than stoichiometric is a rich mixture.  As you can see from the graph, maximum power is produced with a slightly rich mixture (12.6:1) and maximum economy with a slightly lean mixture.
The Slopes of the Curves
As you can see above -- and in the chart below --- power is rapidly affected by lean mixtures...and not affected as dramatically by rich mixtures.
The SRF Air-Fuel Curve
The graph below shows the torque of a Spec Racer Ford motor plotted vs. the RPM.   Torque is shown on the red line and uses the left-side “Y” axis.  Also plotted on this graph is the air-fuel ratio at the same RPM.  The air-fuel ratio is   the dotted black line and uses the right-side “Y” axis.  The blue horizontal line is the stoichiometric point with lean mixtures occurring above the line and rich mixtures below.
The plots below were derived by averaging data from 5 back-to-back dyno “pulls”.  In these pulls, the motor is brought to wide open throttle (WOT) with the dyno water brake holding down the motor RPM and then turning control of the motor over to the dyno’s computer.  The computer then reduces the load on the motor such that RPM increases at 300 RPM per second...all the time holding the motor at WOT.
There are a couple of key points in this data:
1) Between 4000 RPM and 4250 RPM, when the motor is approaching its peak output, the air-fuel ratio is mostly on the lean side of stoichiometric.
2) Above 4750 RPM, the motor goes very rich.
“Detonation and Pre-Ignition -- Evils or Curses?”
Both detonation (spontaneous ignition of part of the fuel charge after ignition) and pre-ignition (premature ignition of the fuel charge by a “hot spot” in the cylinder) can be aggravated by lean mixtures and high engine loads.  Think about how a car “knocks” (detonates) when you accelerate at full throttle in high gear.   This situation is not dissimilar to the SRF situation between 3250 RPM and 4250 RPM....a lean mixture and a high load.  I’m aware of two SRF engines that have been destroyed due to detonation.
To make matters worse, the air-fuel ratio shown above is from data taken from an air-bell mounted at the inlet of the air filter housing.  In other words, we were measuring the total airflow of the motor.  The problem is that the air is not distributed evenly between the cylinders.  The Mass Air Flow (MAF) sensor is providing readings to the Engine Control Unit (ECU) to compute injector pulse width based on the total air flow.  There can be, however, variations between the cylinders of over 15%.   This means that while, on average, the air-fuel ratio is what is shown in the graph above, a specific cylinder might have 15% more or less air at any given moment (with cylinders 2 & 3 flowing the most air)...but the fuel is based on the average.
