Gönderen Konu: honda ecu hata kodları  (Okunma sayısı 7795 defa)
ramo si
  • İleti: 515
« : Ekim 25, 2007, 11:23:24 ÖS »
1 Oxygen Sensor "A" (Primary)
defective circuit or unplugged / defective sensor
2 Oxygen Sensor "B"
3 MAP Sensor (Manifold Absolute Pressure)
4 CKP Sensor (Crankshaft Position Sensor)
5 MAP Sensor (Manifold Absolute Pressure)
mechanical problem / disconnected piping
6 ECT Sensor (Engine Coolant Temperature)
7 TP Sensor (Throttle Position)
8 TDC Sensor (Top Dead Center)
9 CYP Sensor (Cylinder)
10 IAT Sensor (Intake Air Temperature)
12 EGR Lift Sensor (Exhaust Gas Recirculation)
13 BARO Sensor (Atmospheric Pressure)
14 IAC Valve (Idle Air Control)
15 Ignition Output Signal
missing or defective ignition output signal
16 Fuel Injector System
defective circuit or unplugged / defective fuel injector
17 VSS (Vehicle Speed Sensor)
19 Automatic Transmission Lock Up Control Solenoid Valve
defective circuit or unplugged / defective solenoid valve
20 Electrical Load Detector
21 VTEC Solenoid Valve
22 VTEC Oil Pressure Switch
defective circuit or unplugged / defective oil pressure switch
23 KS (Knock Sensor)
30 Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
31 Automatic Transmission Signal "B"
41 Primary Oxygen Sensor - Heater
circuit malfunction
43 Fuel Supply System
defective or malfunctioning fuel supply system
45 System Too Lean or Too Rich
malfunction in the fuel monitoring systems
48 LAF Sensor (Lean Air Fuel)
54 CKF Sensor (Crankshaft Speed Fluctuation)
58 TDC Sensor 2 (Top Dead Center)
61 Oxygen Sensor, Heated - Sensor 1 (Primary)
high voltage, low voltage, or slow response
63 Oxygen Sensor, Heated - Sensor 2 (Secondary)
65 Oxygen Sensor Heater (Secondary)
malfunctioning or defective oxygen sensor heater
67 Catalyst system Efficiency Below Threshold
malfunctioning or defective catalyst system
70 Automatic Transmission
malfunction with the automatic transmission controls
71 Cylinder 1 Misfire or a Random Misfire
a condition is present that is creating a cylinder misfire
72 Cylinder 2 Misfire or a Random Misfire
73 Cylinder 3 Misfire or a Random Misfire
74 Cylinder 4 Misfire or a Random Misfire
75 Cylinder 5 Misfire or a Random Misfire
76 Cylinder 6 Misfire or a Random Misfire
80 Exhaust Gas Recirculation
insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature)
circuit range / performance problem
90 Evaporative Emission Control System
leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor
low input
92 Evaporative Emission Control System
insufficient purge flow
tuner zafer
Ynt: honda ecu hata kodları
« Yanıtla #1 : Ekim 25, 2007, 11:27:35 ÖS »
paylaşım için teşekkürler
ingilizcem olmadığı için anlamıyorum  >=ok
whitehan
  • İleti: 2572
« Yanıtla #2 : Ekim 26, 2007, 12:22:01 ÖÖ »
paylasım tesekk..
35vt787
« Yanıtla #3 : Ekim 26, 2007, 02:41:00 ÖÖ »
 >=ok
umut
  • İleti: 673
« Yanıtla #4 : Ekim 26, 2007, 08:43:35 ÖÖ »
emeğine sağlık >=ok
