ozellikler bunlar arkadaslar
* KFC-W112S
o 12" Car Subwoofer
o Peak: 800 watts
o RMS: 200 watts
o Impedance: 4 ohm
o Sensitivity: 90 dB
o Frequency response: 28-800 Hz
o Injection Polypropylene Cone Woofer
o High-roll Urethane Surround
o Silver Plated Terminals
o Top-mount depth: 5-9/16"
* KAC-1502S
o 2-Channel Class A/B Car Amplifier
o 4 ohms: 60 watts x 2 chan
o 2 ohms: 75 watts x 2 chan
o Bridged, 4 ohms: 150 watts x 1 chan
o Max power output: 175 watts x 2 chan
o Frequency response: 5-50,000 Hz
o MOSFET switching power supply
o Built-in low-pass filter (80 Hz fixed, 12 dB/octave)
o Preamp RCA and speaker level inputs
o Dimensions: 9-1/8"W x 2-3/16"H x 7-1/8"D
General
Type Component
Size 12"
Impedance 4Ohms
Voice Coil(s) Single
Sensitivity 90dB
Peak Power Handling 800 Watts
RMS Power Range 200 Watts
Surround Material Urethane
Cone Material Polypropylene
Frequency Response 28 - 800Hz
Installation
Top Mount Depth 5-9/16"
Sealed Box Volume 1.25cu. ft.
Ported Box Volume 1.50cu. ft.
