HONDA MODELLERİ => Diğer Honda Modelleri => Konuyu başlatan: AngelllA - Mayıs 29, 2007, 04:42:49 ÖS
Başlık: 2007 Honda - Insight Hybrid
Gönderen: AngelllA - Mayıs 29, 2007, 04:42:49 ÖS
(http://img338.imageshack.us/img338/4576/hondainsightdv06das02fn9.jpg)
(http://img518.imageshack.us/img518/977/hondainsightdv06das03tg5.jpg)
(http://img518.imageshack.us/img518/7034/hondainsightintmanu0601vg8.jpg)
(http://img338.imageshack.us/img338/5508/hondainsightintmanu0607gr9.jpg)
(http://img338.imageshack.us/img338/3492/hondainsightmanu0609bl1.jpg)
(http://img230.imageshack.us/img230/6910/hondainsightmanu0604oe1.jpg)
(http://img230.imageshack.us/img230/3817/hondainsightmanu0602cw2.jpg)
Engine
Engine Configuration I
Cylinders 3
Engine VTEC®.
Aspiration/Induction Normal
Displacement 995.00 cc | 60.7 cu in. | 1 L.
Valves 12 valves.
4 valves per cylinder.
Valvetrain SOHC
Horsepower 67.00 BHP (49.3 KW) @ 5700.00 RPM
Torque 66.00 Ft-Lbs (89.5 NM) @ 4800.00 RPM
HP to Weight Ratio 27.6 LB / HP (Vehicles with similar ratio)
HP / Liter 67.0 BHP / Liter
Bore 72.00 mm | 2.8 in.
Stroke 81.50 mm | 3.2 in.
Compression Ratio 10.8:1
Fuel Type Gasoline - Petrol
Fuel Feed Fuel Injected
Multi-Point Fuel Injection - Lean-Burn
Block Aluminum
Head Aluminum
Ignition System Direct Ignition System with Immobilizer
Hybrid System
Electric Motor
Type Permanent magnet electric motor
  ELECTRIC MOTOR / GENERATOR
Power Output 14.00 HP @ 3000.00 RPM
Battery
Type Sealed Nickel-Metal Hydride (Ni-MH)
Voltage 144.00V
Başlık: Ynt: 2007 Honda - Insight Hybrid
Gönderen: GU - Mayıs 29, 2007, 04:50:27 ÖS
Çok şirin ama benim tarzım deil AngelllA'm dökrütüosun yine...
Gönderen: AngelllA - Mayıs 29, 2007, 04:51:49 ÖS
:) Benim de tarzım değil aynı şekilde şirin buldum ... Crx türevi  :kurba
Gönderen: GU - Mayıs 29, 2007, 04:54:47 ÖS
Kesinlikle I do agree with you
Gönderen: Can_DCK - Mayıs 29, 2007, 04:56:01 ÖS
Beğenmedim  >%Sakin
Gönderen: deeperblack - Mayıs 29, 2007, 06:47:03 ÖS
Böyle olmaz delikanlıyı bozar valla
Abi şarjım bitti bi el atsanız şu yokuşa kadar :P
Paylaşım için teşekkür ederim....
Gönderen: AYCA - Mayıs 29, 2007, 09:27:57 ÖS
bence hıc bır cazibesı yok..
